Upboard MIPI DSI
JOSHUA SIRKIN
Posts: 17 ✭
Has anyone found a 5 inch touchscreen that works with the up board? Is the MIPI-DSI port on the upboard the same as the one on the raspberry pi? The connector looks smaller. I found this https://www.dfrobot.com/product-1784.html screen but not sure if it would even connect. If the connector is different, is there an adapter cable product available for using the upboard with raspberry pi DSI screens? I specifically need a 5 inch screen.
