How I can to protect BIOS settings?
Hi, I just updated BIOS to latest revision. Changed admin password, but... here is still to able to enter in BIOS settings as user, so this admin password looks like no usefull in BIOS settings protection.
And when user password is setted - it prevent to normal boot OS.
How it can be fixed?
I´m bumping this thread because I´m having this exact problem with current UP board BIOS version.
At the company I work we have many UP-Squared units and I need to protect some specific settings in the BIOS for security reasons.
I upgraded firmware to latest: UP-APL01 R5.0 (UPA1AM50) (12/17/2019)
If I set up a BIOS admin password, the normal user is still able to enter BIOS pressing enter with blank password. If this happens a malicious user can mess with all the boot options.
On the other hand, if I also set a user password it prevents normal boot because always asks for a password when booting.
The descriptive text in the Bios section "SECURITY" is misleading because the admin password does not limit access as normal user:
If ONLY the Administrator's password is set,
then this only limits access to Setup and is
only asked for when entering Setup.
If ONLY the User's password is set, then this
is a power on password and must be entered to
boot or enter Setup. In Setup the User will
have Administrator rights.
Please upgrade UP board Bios so access can be password protected but allowing normal boot of the computer.
@Klez
Yes, this is the BIOS security rules.
In your case, the only way to limit access for normal user is to remove the user mode in BIOS, and it need customized BIOS.
Hi @Klez
As mentioned by @rogertsai(AAEON) you would require customized BIOS. if you would like that, you can purchase from our shop " https://up-shop.org/18-software "
Thank you for your answers. I'll pass this info to my managers so they can take a decision.
