Mounting LTE module
I have bought this up squared : https://up-shop.org/home/285-up-squared-ai-vision-x-developer-kit.html
And this LTe module kit: https://up-shop.org/home/237-mpcie-lte-module-kit-emea-only.html
I was told to buy an adapter as well from you guys ; https://up-shop.org/up-peripherals/125-3gwifibt-module.html?search_query=3G+WiFi+BT+adapter+module&results=5.
Please see attached images.
How do i mount this together?
It seemed not right when i tried, it has been mounted on the 40 pins but are not supported in some kind of way?
And the long spacer sleeves can not be fitted noe which lock the top to the bottom. Please explain where I have done it wrong and how to mount it , step by step
On the last picture you see there is a small 10 pin connector.
With the 3G HAT you should have received a cable to connect the board with the HAT
The main connector should be connected to the UP Squared, one of the secondary goes into the 3G HAT.
About the spacers the one included in the chassis are not fine and you need to get a different size.
Please let me know if the HAT works for you after you connected the cable.
