All our newsletters are officially released <a href="https://up-board.org/newsletter-archive/">here</a> now via our official mailing list.
Join our mailing list <a href="http://eepurl.com/bHfeID">here</a>.
[NPI] UP Shop new product introduction
We had added a lots of new products since 2019, and we would like to have a summary for you.
New UP Squared fanless chassis
By introduction new ATOM SKU, we have to make different chassis to fit different CPU due to the height of CPU. In the meanwhile, we also make it possible to accommodate the heat-pipe if users would like to install AI Core X inside.
PN:EP-CHUPSMTVAC&P & EP-CHUPSMTVBPLX
Heat-pipe of AI Core X
To add AI Core X into UP Squared chassis, we suggest to replace the passive heat sink with a heat-pipe. It dissipates the heat efficiently and brings you the full performance of AI Core X without throttling.
PN:EP-FNAICMX-2485
AI Core XP4 & AI Core XP8
You want to have more, more and more Myriad X ? We designed a PCIe[x4] card to accommodate 4 slot of AI Core XM 2280. The standard product will be based on 4x Myriad X on board, or 8x Myriad X on board. This could be a good way for you to try out how many Myriad X you really need for your project and help you to scale your vision accelerator.
PN:PER-TAIX4-A10-PCIE (AI Core XP4 )
PN:PER-TAIX8-A10-PCIE (AI Core XP4 )
LoRa Edge Compute
A line-up of LoRa Edge Computes are introduced at UP shop. They are powered by UP or UP Squared. We have different flavors available no matter with dev. SW or w/o dev. SW. UP team works with LoRa SW leader, The Things Network, ResIoT, IoT in a box, to make your LoRa project easy and quick.
PN:
RE-AIOT-ILRA01-A10-CA40232EU
RE-AIOT-ILRA01-A10-CA40232EU-NWK
RE-AIOT-ILRA01-A10-CA40232EU-IOT
RE-AIOT-ILRA01-A10-CA40232EU-IIB
UPS-EDLA-X70864-UW01
Automation Compute
Will UP be a solution for automation? Yes, we make AIO and serial ports available. In addition, we also bundle ESF automation IoT management SW. Check it.
PN:
RE-AIOT-IGWS01-A30-CA40232EURF
RE-AIOT-IGWS-CA40232EU-ESF01
