Actual Window Manager Latest 2027
Automation of routine window manipulations! Must-have software for multi-monitor setups Your several times
🔴▶️Click here to Download Link✔️
If you have a lack of workspace on the desktop, use virtual desktops included in Actual Window Manager. This tool allows you to create the desired number on virtual desktops and increase your workspace. Configure your OS as you wish.
With the Window Manager, you can set many parameters for each window individually.
Hotkeys are the tool of professionals, and the app supports them in full. Most of the program functions can be activated via hotkey, and you can customize the key combinations at will.
Moreover, you will be able to add your own hotkeys for some window operations. The divider allows you to split the entire large desktop or each monitor into several non-intersecting areas (tiles). If you place a window into one of such tiles, the window will expand up to tile’s borders only.
You can create as many custom tile layouts as you need and activate them on the fly, as circumstances require. More than 50 desktop management tools for your Windows PC!
It allows the use of two additional title buttons for each window. These special buttons improve Windows Folder Navigation, so you do not need to use long mouse manipulation to follow through to the desired folder.
It has a lot more smart uses that It leaves for you to discover.
The following list of its full functionality may give you a certain insight into what benefits you can expect from the program.
Clipboard Manager - improves Windows clipboard functionality with 2 additional features: Clipboard Templates and Clipboard History.
Desktop Divider - allows you to split the entire large desktop or each monitor into several non-intersecting areas (tiles).
File Folders - improves Windows folders navigation adding two additional title buttons.
Individual Settings for Each Window - allows you to set individual settings for the desired window, folder, or program.
Multiple Monitors - greatly improves your multi-monitor environment adding additional fully-functional taskbars and other useful tools.
Additional Title Buttons - adds additional buttons, such as minimize to tray, stay on top, roll up, etc, to the title bar of each window.
Virtual Desktops - allows you to use an unlimited number of virtual desktops on one or several monitors.
What`s New
Startup speed improved, with enhanced security via page hashes in executable files.
Compatibility restored for Windows 11 24H2's Actual Taskbar, addressing:
Random crashes when showing task button previews.
Restored system tray functionality.
Automatic hiding/showing of the system taskbar when replacing it.
Fixed "Move to Monitor - Primary" startup action.
Actual Taskbar: Addressed taskbar freezing caused by apps hanging or being suspended.
Title Buttons: Reduced CPU load caused by extra buttons in misbehaving apps.
Tabbed Explorer: Folders now correctly placed into containers
