Actual Multiple Monitors Version 2028
Actual Multiple Monitors improves the Windows PC user interface when working with several monitors at once.
Get fully functional taskbar with Start menu and system tray on each monitor
🔴▶️Click here to Download Link✔️
Quickly move windows between monitors
Set its own wallpaper and screensaver on each monitor
Play a game on one monitor and chat, surf web, etc. on others
Connect as many monitors as you need (up to 64 monitors supported
Install Actual Multiple Monitors to get such essential controls as Taskbar, Start menu, system tray, and Task Switcher on each connected display, quickly allocate windows between monitors (either manually or automatically
Play your favorite games on one monitor and chat, surf web, stream online video, etc. on the others at the same time without fear that the game will minimize. With these subtle but indispensable enhancements, your productivity may be increased several times
Actual Multiple Monitors provides the following specially designed tools to maximize the speed and comfort when working with a multiple monitors setup:
Multi-monitor Taskbar - makes window navigation quick and easy on secondary displays
Multi-monitor Task Switcher - cancels the need to turn your attention to the primary display every time you switch between tasks using Alt+Tab
Multi-monitor background wallpaper - gives additional abilities to customize the desktop background
Multi-monitor screen saver - allows running any screen saver in a multi-monitor mode
Desktop Divider - allows you to divide the entire large desktop or each monitor into several non-intersecting areas (tiles).
Desktop management tools - provides various tools to manage the multi-monitor desktop efficiently: desktop profiles, desktop icons manager, etc.
Desktop mirroring tools - provides various types of desktop mirroring to improve the workflow
Advanced multi-monitor window management - speeds up the allocation of windows within the extended desktop
Multi-Monitor Mouse provides additional abilities for using a mouse in work and games on a multi-monitor system
PROS
Improved Multi-Monitor Navigation
Customizable Taskbars
Seamless Window Management
Enhanced Desktop Divider
Flexible Hotkey Options
CONS
High Resource Usage
Limited MacOS Compatibility
Occasional Software Glitches
