M.2 and PWM
ZJiang
ZJiang New Member Posts: 1 ✭
Hi, I have a couple of questions:
  1. in your user manual, I can see the board has a M.2 port. On page 2 (1.1 Specifications) it says it is a M.2 2230 port but on page 9 (2.3 List of Jumpers and Connectors) it says it is a M.2 2280 port. By the look of it, it is more likely to be a 2230 port for a wifi card. Can you confirm this for me please?
  2. Can you confirm the PWM ports have hardware timing? I want to use them to control servos precisely
  3. What's the maximum power I can draw from the USB 3.2 and 2.0 ports at the same time? I need to connect some power hungery USB devices to the board at the same time.
  • HarryChiu
    Hi @ZJiang
    1. Could you please confirm whether you are referring to the specifications of the UP 710S?
    I could not find any mention of M.2 2280 in the document. Are you referring to this version of the manual??
    https://www.aaeon.com/en/product/detail/up-boards-up-710s/download
    1. Could you please provide a sample or example of the data you need??
    We would like to make sure we understand your requirements correctly before proceeding.
    1. We designed the USB 2.0 and USB 3.0 ports in accordance with the standard specifications.
      Each USB 2.0 port can provide approximately 500 mA.
      Each USB 3.0 port can provide approximately 900 mA.
    Harry Chiu
