UP TWL Board Support
Hey, the UP TWL Product Information, Datasheet, and Wiki pages mention that the UP TWL supports Yocto and uses the usual 40pin header etc.
However the UP TWL is not mentioned in any of the documentation:
- Yocto GSG supported boards list or meta-up-board yocto machine configuration directory
- the 40pin board mapping tablesx
- Spec Matrix Overview Atom wiki page
There also isn't any UP TWI category here in the forums, so I can only post to the FAQ section.
I guess this means that it is probably similar to some existing board, but which existing board? When using yocto to build an image for the UP TWL, which machine configuration should be used and what yocto versions are supported?
Hi @ddd_sol
You can create an image using up-xtreme-i12, and the version should be Yocto5 Scarthgap.
Harry Chiu
