INTEL AX210 WI-FI MODULE CONNECTIONS
Milasota
New Member Posts: 2 ✭
Hi
I need the following information about the UP4000:
1) What type of interface does the Wi-Fi module (INTEL-AX210) mounted on the "carrier board for Wi-Fi and 5G" use? Is it the PCIE bus,the SMBus or the USB 2.0 port?
2) Is it possible to obtain the wiring diagram for the Wi-Fi module (INTEL-AX210) on the CN21 (high-speed expend connector)?
3) How do pins 29 and 30 of the CN21 (high-speed expend connector) work?
Best regards
Hi @Milasota
- The AX210 uses a PCIe interface to Wi-Fi and a USB interface to Bluetooth.
- Please refer to the attachments. The main board CN21 is same as the carrie board CN1.
- Please refer to the figure. Also you can find this in user manual.
https://www.aaeon.com/tw/product/detail/up-developer-board-intel-apollo-lake-up-4000/download
Harry Chiu
