Using the SDK Setting the PWM frequency,......
In the SDK there appears to be only two commands in relation to the PWM, Set and get.
The "EApiPwmSetValue" uses 4 input values. But none of these values change the frequency of the PWM.
At present the minimum frequency at 17Mhz when the command is initialised with the following:
EApiPwmSetValue(0,1,0,1)
with the first variable being the PWM ID number,
Second is the Base Unit Integer
the third is the Base Unit fraction - which cannot be set to anything but 0 for some reason
the forth is the duty.
So the question is. How do you set the Upboard PWM frequency to its minimum of 293Hz?
  • I like the way you described it but will you please clear are these steps are useful or not.
  • free robux generator is a online website to generate the free robux currency which allows you to unlock various gaming accessories and characters and bring a new touch to the online game.
    WIth the access to the website you will clearly found the option to generate the free robux for your favourite game and as after entering gaming credencials in the website you can easily get the currency generated and unlock various accessories you love.
    free robux generator is a online website platform to generate the free robux currency which allows you to generate the free robux currency to unlock various gaming characters and accessories and bring a new touch to the online gaming .
    For the generation process you have to just login to the website and generate the currency. As on the currency is on the mark get the currency transfur it to your gaming id.
