OS doesn't load
We are packaging machine manufacturers and we are using UP Squared Pro 7000 with CODESYS Runtime as SoftPLC controller. We are still in tryout phase and this morning when I powered up the machine, it did not work. The noticeable symptom was the network was down. I, then remove it from the machine ad powered up. All I could see was the BIOS password prompt. I reinstalled the OS (Ubuntu for Intel IoT platforms - Intel® Atom® X7000E Processors Series - Ubuntu Server 22.04 - https://ubuntu.com/download/iot/intel-iot). The installation was completed with no errors. Once prompted, I removed the USB stick and rebooted the PC. And, again, all I could see was the BIOS password prompt.
I disconnected RTC battery and let it powered off for couple of hours. Reconnected battery and powered on. Once again, all I could see was the BIOS password prompt.
What could be the issue(s). How to toroubleshoot it?
Thank you,
F.
