UP 4000 - USB PORT
Milasota
New Member Posts: 3 ✭
Hi
I'm trying to replace the EOL UP board with the UP 4000 board.
I've previously used the following USB 2.0 ports:
P0 on CN40
P2 on CN7
P3 on CN7
Can I found the same USB 2.0 ports on UP 4000 BOARD ?
UP 4000 description lists 2 USB 2.0 ports only but in data sheet I found
DP0/DN0 CN4
DP1/DN1 CN4
DP/DN_P1 CN5
DP/DN CN21
DP/DN_P6 CN15
DP/DN_P7 CN15
Best regards
Hi @Milasota
CN7 of the UP board is the same as CN15 of the UP4000.
Is the USB 3.2 port unusable??
Connect this cable to access the USB 2.0 port.
This cable is suitable for all UP boards.
https://up-shop.org/default/usb-2-0-pin-header-cable.htmlBest Regards,
Harry Chiu
