Up 7000 eMMC Windows 11 IoT support?
I have built a Win 11 IoT Enterprise image and am trying to run it on the Up 7000. I made a bootable USB drive and am able to get it to boot and select the hard drive to install to. I select the onboard eMMC drive.
But after files are copied over and a reboot happens I end up right back at the install drive selection.
Removing the thumb drive I can get to the boot device selection list using F7, but selecting that just results in coming back to the boot device selection list.
Letting the device boot normally I end up at the UEFI shell.
I tried the Windows 11 IoT image from Microsoft with UP7000, it works normally.
https://www.microsoft.com/en-us/evalcenter/download-windows-11-iot-enterprise-ltsc-evalCould you please provide me your image??
Harry Chiu -
Did you get all the way to windows boot? I just tried that image and ended up in the same install loop asking for what drive to install to. I am using the built in eMMC drive. I have a team mate that used an SSD add on and it worked. But not with the built in drive.
I use a USB drive to install the OS to eMMC, and I can enter Windows Desktop.
Have you removed the install drive??
In the BIOS settings, the boot priority is USB as the highest, which is the default value.Best Regards,
Harry Chiu -
I did remove the thumb drive. And end up booting to either the eufi shell or back to the bood drive menu.
It feels like it is not installed in emmc.
Can emmc still be detected during Windows installation??What bios version are you using??
Harry Chiu -
Where do I check the bios version?
Please press "DELETE" when powering-on, no password required to enter.
You can check the version of bios in main page.
Harry Chiu -
UP-ADLN01 R2.1 (UNADAM21)(04/18/2023)
Boot priorities are:
Hard disk: Windows boot manager (emmC TY294)
USB Hard Disk
NVME
USB Key
USB Floppy
USB Lan
USB CD/DVD
CD/DVD
Network
UEFI AP:UEFI: Built-in EFI Shell -
Please update your bios, it can be downloaded at this website.
https://www.aaeon.com/tw/p/up-board-up-squared-pro-7000Please refer to the link, it will teach you how to update bios with UEFI shell.
https://github.com/up-board/up-community/wiki/Firmware#uefi-bios-historyBest Regards,
Harry Chiu
