won't boot after installation
Josef
Posts: 3 ✭
after installing the newest ublinux OS i can reach only the login screen. The screen is freezing after the Login. The same happend when i tried ubuntu. I am using a 5V/2A Powersupply. Can this cause the issue? I though it would be instable instead of freezing if the power is too low.
Thanks for your help.
Hi Sheepocado,
Do you have the same problem if you install any other OS?
If so, I would try another power supply, it might be not good enough (or stable enough). -
well, i failed installing windows 7. I have no key for Windows 8.1+. Is there a way to install without an key like the 30 days trail in windows xp?
well... bought win 8.1 an it is working. thanks
