The RAID of UP Squared
kukucck
New Member Posts: 1 ✭
Can I link a RAID(with 40TB) to UP Squared?
On UP Squared you have 2 SATA ports (one via standard SATA connector, the other via miniPCIe).
The RAID support is only via SW (Linux RAID for example) which should be limited to 8TB disks support.
Unless you use a miniPCIe card with hardware RAID support, I don't think you can manage a 40TB RAID directly.
