how to enter bios on up2
i have decided to reinstall os on the up2 however i am failing to enter bios
what keys i have to press in order to get to bios
so far tried "f7" and "Delete" without luck so far.
I even removed battery and that was not a good idea because I had up2 kickstarted eddition with sandisk emmc which is buggy and i need to set it to ddr50 instead of h400 according to troylin see below:
Hi All,
To resolve the 128 eMMC timeout issue, a setting in the BIOS needs to be adjusted
In the BIOS menu under Chipset, please adjust the eMMC Max Speed from HS400 to DDR50
The reason for this is because the 128GB eMMC is from SanDisk, and the flash controller that SanDisk uses require the Speed to be DDR50, the end result is a slower eMMC read/write performance comparing to other brands such as Hynix or Samsung.
We have highlighted this issue to SanDisk and there is no resolution, therefore, we have decided for MP version of UP2, we will use Samsung for the 128GB SKU. We have tested the Samsung 128GB on UP2 and it runs at HS400 (EMMC 5.1) for all different OS such as Windows/Linux/Android.
Thank you for understanding.
please help me with this
fyi , if i set next boot via efibootmgr to built in uefi "efibootmgr -n 0003" there is no output on my tv,
I have 3 options in efibootmgr
0001 debian
0003 builtin uefi
0004 kingston flashi have changed default boot order to builting uefi and now i am not able to do anything.
I am starting to loose trust in that board, how ever i think waranty should be still in place right?
where I can send it? -
update
i removed battery again, booting to os restored
current possible targets:
0001 - os
0002 - builtin uefiwhen i try to set 0002 to next boot still no output to tv screen
any idea?
strange, i connected usb again, also connected utp cable and i got aaeon welcome screen, pressed f7 and i was able to enter bios finally
Tagged
- 105 Announcements & News
- 185 Welcome Developers!
- 49 Tech Updates
- 693 UP Products
- 11 UP 7000
- 10 UP Xtreme i12
- 11 UP Squared Pro 7000
- 19 UP Squared V2
- 59 UP 4000
- 35 UP Squared 6000
- 60 UP Squared Pro
- 143 UP Xtreme
- 837 UP Squared
- 222 UP Core
