up core plus + net plus + lte/4g module
will this combination work in Australia?
If i'm looking things up correctly EMEA means Europe, Middle East, Asia. But it also seems that it works in America. so i'm confused.
my hope is to use it as a pfsence gateway using multiple internet connections with lte/4g as a "fail safe"
currently use an up^2 at home. want to test this new set up at home before I put it in my business.
2 x UP board, 4GB RAM + 64 GB eMMC w/ vesa case
1x UP Squared Pentium Quad Core, 8GB RAM, 128GB eMMC w/ vesa case
1x UP Core Plus E3950, 8GB RAM, 64GB EMMC+ Net Plus i210-IT
1x Dell Power Edge R510
2x Dell Power Edge R610
    DCleri Posts: 1,213 admin
    Hi Andrew,
    Unfortunately we won't have a 4G module for Australia before May 2019, but only 3G for now.
    You can eventually test with a 3G modem and switch to the new one, once available.
  • Andrew Hays
    Andrew Hays Posts: 45 ✭✭
    will it support running as a hotspot?
    Hi Andrew,
    Yes the WiFi onboard the UP Core Plus also works as access point.
