GPIO pin state reset when script terminates
ErezFL
New Member Posts: 2 ✭
I was using Rpi before and changed to Up.
Using the patched Linux to enable GPIO pin set\get.
Using the same python scripts I was using on Rpi
I can change and set the right pin state to high\low.
However, on the UP when the script terminates the pin state ALWAYS resets,
meaning while on Rpi I could change the pin state to high and
it remained in this state until explicitly changed even when the script terminated.
Can you please advice what needs to be changed\configured for so the pin state
would not reset when the script terminates ?
Thank you :-)
Could you share the script that you are using?
sure, it's a very simple one
!/usr/bin/env python
import RPi.GPIO as gpio
if name == "main":
returncode = 1
gpio.setmode(gpio.BCM)
gpio.setwarnings(False)gpio.setup(17, gpio.OUT) gpio.output(17, gpio.LOW)
Tagged
- 303 All Categories
- 184 Welcome Developers!
- 24 Tech Updates
- 595 UP Products
- 6 UP Xtreme i12
- 1 UP Squared Pro 7000
- 13 UP Squared V2
- 41 UP 4000
- 49 UP Squared Pro
- 140 UP Xtreme
- 828 UP Squared
- 221 UP Core
