Voltage Supply Tolerance
I want to power the Up-Board with Lipos and an SBEC. The output Voltage of the SBEC is 5.2 V i wanted to know if the board can handle this?
  • [Deleted User]
    [Deleted User] Posts: 0 ✭
    HI,
    if you could guarantee that the value will NEVER be > than 5.2V then it is ok
    if it will be 5.2V + tolerance then it is not possible as 5.25V is the limit for the USB VBUS which is directly connected to AC/DC
