UP Core Plus Carrier Board Design Guide
I haven't received my UP Core Plus yet but I'd like to start working on the design for our carrier board.
The UP Core has an excellent design guide with precise measurements of the location and function of the 100 pin header, is there a version that describes the UP Core Plus and the 2nd 100 pin header?
  • eduncan911
    Hello and welcome to the forums!
    I will pass this along to get the design guide. It should be posted to the Downloads section when it is available.
    In the meantime, you may have seen it already but here's the UP Core Plus specifications which has the pinout of the two 100-pin connectors:
    https://up-board.org/wp-content/uploads/2018/02/Data-sheet-UP-Core-Plus-copy.pdf
  • christofu
    christofu New Member Posts: 2 ✭
    edited October 2018
    Thanks! I'm specifically looking for any documentation providing precise measurements for the location of both 100-pin headers. Do you know a rough timeline for when the Design Guide might be available? (Or somehow get the measurements). I'd really like to get started on the layout of our carrier board :smile:
    Hello Christofu,
    The final design guide is not available yet but it will be in a couple of weeks at most.
    I will let you know once it will be published.
  • dhargrov
    dhargrov New Member Posts: 1 ✭
    @DCleri is the Up Core Plus carrier board design guide available?
  • Anton Bachmayr
    Anton Bachmayr New Member Posts: 2 ✭
    I‘m also eagerly waiting for this Document! Do you have a reliable timeframe for us when it will be available?
  • Anton Bachmayr
    i received my UP Core Plus this week and would really like to get started on my Carrier board design. would it be possible to at least share a mechnical drawing of the connector Layout - for me it would not Even need to be a complete design guide for now.
  • rreignier
    rreignier New Member Posts: 67 ✭✭
    Does anyone managed to get the precise measurements of the location the two 100 pin headers?
    I have read the "UP CORE PLUS_Carrier Board_Design Guide_2019_0320_a01.pdf" but did not found this information.
  • dpitchfo
    dpitchfo New Member Posts: 5 ✭
    Here is something I did from the UP Core Plus cad file for the placement of the 100 pin connector. I used the CAD and determine the center location of the each of the 100 pin connector. I have not validated the positions. Still working on that. The position to the center of the 100 pin header. Keep in mind this is the UP CORE PLUS board. The carrier board will need to be mirrored.
    Can AAEON update the cad drawings and post the gerbers, schematic and bom of the carrier boards?
  • rreignier
    Thanks for your drawing @dpitchfo
    It seems that one of the connectors is at the same place than on the UpCore (for compatibility) and the second one is exactly centered on the side. But a proper documentation would have been great. It is not very serious from AAEON to provide a design guide without the interface connectors positions. Sorry @DCleri but in your linked document, I have looked several times but never found this information. If I have missed it. Please, points me to the correct page directly. Thank you.
    @rreignier
    You are correct, I will request internally to provide a new document with the detailed information about the connectors position.
    Thanks for your feedback.
  • toshas
    toshas New Member Posts: 12 ✭
    @DCleri said:
    @rreignier
    Hi!
    Is there any news about new document revision (with connectors positions) ?
    The document has been updated and it includes now the 100pin connectors positions:
    https://downloads.up-community.org/download/up-core-plus-carrier-board-design-guide/
    Please let us know if you may have any other feedback.
  • toshas
    Many thanks!
