USB3.0 with RealSense D415 not working
alxsystems
alxsystems New Member Posts: 2
I've bought an UP Board (http://www.up-board.org/up/) and I want to use the Intel RealSense D415 device with it.
The problem is that the D415 needs an USB-C to USB-Micro-B cable because it needs to connect to UP board through the USB 3.0.
I'm not able to find a such cable. I've tried a lot of cables and one of the sensors (it has normally depth, color, infrared sensors, but color's sensor is not there) that compound the D415 is not recognized and I cannot grab images from it (timeout error when trying to grab).
Here is an example of a cable I've bought :
https://www.amazon.fr/DeLOCK-0-5m-USB3-1-MicroUSB3-1-Micro-USB/dp/B017L3TR8E
On an UPSquared, I can have the D415 camera working by pluging the camera to one of its USB3 ports.
Can you give the specifications for the USB 3.0 port on the UP Board and the one for the UPSquared, or can you help me finding a compatible usb-cable working with the intel RealSense D415 ?
Is it because the USB 3 is OTG ?
Best regards,
Christophe Balthasart
