electronic music setup
Rob
Rob New Member Posts: 7 ✭
An electronic music instrument I've been working for about a year now. So far up2 has worked like a charm. I still need to do most of the software for audio processing, so its exciting to see how up2 will able to handle everything.
Running on upsquared in combination with a teensy board, up2 does all the audio processing and controls lighting via spi and i2c, midi-out via uart, teensy does all the input which is send to up2 via usb-serial. software in c++ and puredata.
