2nd I2C Bus Occasionally Fails
figsys
figsys New Member Posts: 5
Have been running Ubilinux and MRAA 1.9.0 and using both I2C ports to talk to 2 seperate devices (1 per I2C bus). However, occasionally the second I2C (on pins 27/28) fails on typically first read operation - here's the error in the journal file
Jul 12 19:08:54 ubilinux4 libmraa[1880]: i2c_init: Selected bus 1
Jul 12 19:08:54 ubilinux4 libmraa[1880]: i2c0: write_byte: Access error: Remote I/O error
Normal operation is something like this
Jul 12 19:49:27 ubilinux4 libmraa[4334]: Adding i2c bus found on i2c-1 on adapter .
Jul 12 19:49:27 ubilinux4 libmraa[4334]: Adding i2c bus found on i2c-0 on adapter .
Jul 12 19:49:27 ubilinux4 libmraa[4334]: i2c_init: Selected bus 0
Jul 12 19:49:27 ubilinux4 libmraa[4334]: i2c_init: Selected bus 1
Need a restart to get this to work. Anyone else experience this issue or has used both buses with no issues? Anything else to look for to troubleshoot?
  • ccalde
    Hi @figsys ,
    1) What is the BIOS version you are using there?
    2) Did you install the last Ubilinux version including the MRAA? https://emutex.com/products/ubilinux
    2) Did you see that issue using only one port at the same time?
    Thank you!
  • figsys
    @ccalde said:
    Hi @figsys ,
    Thank you!
    BIOS Revision 5.11
    Linux version 4.9.45-ubilinux+
    MRAA Version: v1.9.0-48-gc563e4f
    Issue never happens when running only port 0. Also happens when running only port 1 but most of our failure data is for running both ports.
    Thanks!
