Board doesn't start , led on, maybe i broke it ?
Hi , i just got an upboard and i am trying to start playing with it.
The board is not starting , the Led is on , and sometimes it blinks . But i have one other issue , i tried powering the board from a pc power supply because i did not have any 5V/3A power supplies , but i made a mistake and power the board with reverse current, (i connected the + on the board to - on the power supply , and the same with the - ). The board does the same thing now as it did before it just powers the led , and nothing happens .
could i damaged the board when i powered it ?
  • UICalculus
    UICalculus New Member Posts: 1 ✭
    You should check your HDMI port and try another display.If it doesn't work,try to hold "F7" when starting it to enter BIOS.
  • AIS
    AIS New Member Posts: 1 ✭
    If you reversed the input to the board it is likely damaged, they do not seem to have protection for reverse polarity.
