New Metal Case Design for Up^2 board?
Orchestrator
Orchestrator New Member Posts: 15 ✭
I've installed the Up^2 board with a Samsung SSD. In addition I've got the "EnOcean" module. The board is mounted up-side-down and leaves the module only connected to the GPIO. It would be good if there's a way to secure the add-on boards in some way.
There should be a way to connect and external HDD via the onboard SATA. There is no way to get the cable outside the enclosure.
A way to mount the two USB 2.0 pin header cable on the chassis is needed as well.
Regards, O.
