ERROR ADD REPOSITORY ubilinux/up
mmedina
Posts: 1 ✭
Hi friends
I have installed Ubuntu 16.04.4 LTS and I have this problem.
When I try add the respository with the command sudo add-apt-repository ppa:ubilinux/up ocurre this issue "" gpg: solicitando clave E952D27B de hkp servidor keyserver.ubuntu.com
gpgkeys: key E952D27B can't be retrieved "" and I can't install the upboard's kernel.
Hi @mmedina ,
The Ubilinux repository was created thinking on 16.04.3 Ubuntu. So, that could be your issue.
A new release with 16.04.4 and new kernel is coming.
So, you could use that Ubuntu in your UP.Cheers!
