Linux GPIO
I followed the instructions on Up wiki to manipulate PIN13 on up2 but failed to write 1 to file value which maintains 0 after setting the direction as 'out'.
Is there any probability that the pin graph on Up wiki is not correct because I figure out another Pinout graph without mapping NO.
    what Linux distribution and kernel version are you using?
    Also are you using the commands as root or normal user?
