Core Case Issue
khoogheem
Posts: 1 ✭
Just bought a Up Core and the Cores Metal Case.
The Core had its heat sink pre-installed..
The Issue:
you can't fit the Core into the case designed for it with the factory heatsink!!!!
Yes the Case has its own, but if I order both at the same time it would have made sense not to pre-install the heatsink so it could use the cases..
Especially given how much of a pain it is to remove the heatsink!
