battery hat susv is not detected on one of two reboots
i'm facing an issue that after one of two reboots the battery hat susv is not detected.
Attach the system information when the device is present and not. I can't find any difference in the i2c definition...
anyone facing the same issue?
NOTE: i don't have the last firware from susv because it also reproduces this issue and introduces another one (reboot on power failure.. https://forum.up-community.org/discussion/2851/s-usv-ups-firmware-version-2-40-reboots-after-power-failure)
  • asilva
    asilva Posts: 13
    well.. just figure out the issue.. the i2c device changes after the reboot.
    I could detect the new i2c device by probing with i2cdetect -r DEVID, one of the times it was the id 5.
    root@ubilinux4:~# i2cdetect -r 5
    WARNING! This program can confuse your I2C bus, cause data loss and worse!
    I will probe file /dev/i2c-5 using read byte commands.
    I will probe address range 0x03-0x77.
    Continue? [Y/n] y
    0 1 2 3 4 5 6 7 8 9 a b c d e f
    00: -- -- -- -- -- -- -- -- -- -- -- -- 0f
    10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- --
    70: -- -- -- -- -- -- -- --
    The 0x0F indicates de s.usv hat.
    After that, in the configuration file /opt/susvd/susv.cfg, with version 2.40, set the parameter i2c device:
    [i2c]
    device="/dev/i2c-5"
    anyone knows how to prevent i2c device from change on reboot?
  • Hi,
    I am facing similar difficulties. Have you (or anybody else) gotten any closer to a solution?
  • rchauvin
    rchauvin Posts: 14
    Same here, the i2c device changes after the reboot.
    I didn't find a solution yet..
  • rchauvin
    rchauvin Posts: 14
    Here is the answer from S.USV support about the issue:
    "We can confirm that this a well-known problem within Ubilinux and is dedicated to the OS itself. A lot of users independently of the S.USV users already reported this problem to the manufacturer (Aaeon) but without any success up to now."
  • ccalde
    ccalde Posts: 348 ✭✭✭
    edited December 2018
    Hi all,
    Thanks for the information, we will take a look at that issue.
  • rchauvin
    rchauvin Posts: 14
    @ccalde said:
    Hi all,
    Hi @ccalde,
    Have you had time to look at this issue?
  • ccalde
    Hi @rchauvin ,
    Unfortunately, not yet.
    Could confirm that issue is only for Ubilinux and not for UP board Ubuntu 16.04?
  • rchauvin
    rchauvin Posts: 14
    Hi @ccalde,
    Initially I installed Ubuntu 16.04 on the UP squared board. But I had too many issue to get the S.USV working properly on Ubuntu. So I ended up by installing Ubilinux. It is working except for this reboot issue.
    According to Olmatic GmbH:
    "The only way to solve this issue in the meanwhile is to create a script, executed at boot time, which checks the correct i2c-bus and automatically changes the “susv.cfg” before starting the Daemon."
    I would prefer not to go for this workaround.
  • ccalde
    Hi @rchauvin ,
    Thanks for the update for Ubuntu.
    As soon as possible I get a battery hat here, I will check that issue.
