S.USV UPs firmware version 2.40 reboots after power failure
asilva
New Member Posts: 13 ✭
hi,
With last firmware version, 2.40, it reboots after i unplug the energy. Is this a bug (it didn't occur with previous firmware!) or some desired configuration (how can i disabled it)?
anyone experience the same behaviour?
NOTE: the susv daemon is not running.
root@ubilinux4:~# /opt/susvd/susv -status
- S.USV solutions *
- www.s-usv.com *
- Model: UPs *
- Firmware Version: 2.40 *
- Software Version: 2.32 *
- Mail notification: Disabled *
- Timed Boot: Disabled *
- Boot time: 00:00:00 *
- Timed Shutdown: Disabled *
- Shutdown time: 00:00:00 *
- Mon Mar 5 23:20:59 2018 *
- Powering Source: Primary *
- Charging circuit: ONLINE *
- Charging current: 300 mA *
- Voltage in: 5.11 V *
- Battery capacity: 100.00% *
- Battery voltage: 4.20V *
- Power Battery: 000.00 mA *
- Power Extern: 000.00 mA *
- Shutdown timer: -1 *
- Autostart: disabled *
- Sleep timer: 1 *
just test new version 2.51 and i can confirm that is fix.
- Changes V2.51 - 03/21/2018
- Bugfixing power off system after shutdown process
