How to use i2c on Up board and Ubilinux 4 ?
Hello there,
I'm confused using my Up board and an i2c Grove LCD screen. I was able to use it with a previous Intel Galileo board (Arduino compatible running under Yocto Poky). Now I want to use it with my Up board but it doesn't seem to work. And I don't find any solution.
When I connect the screen, the screen is supplied and I check that I'm using correct pins : 2 for VCC, 6 for Ground, 3 for SDA and 5 for SCL.
I know my code works because it worked on my Intel Galileo. Now that I want to use it on Up board, I need LCD_I2C_ADDRESS and RGB_I2C_ADDRESS.
I did some search on internet but nothing helped me, except the command "i2cdetect 0". So I tried this command and I show you what I got:
It's the same by replacing 0 by 1. Does anyone else encountered this ? Any solution ?
Thank you.
Dear,
Have you try with port 1 ?
sudo i2cdetect -y -r 1 -
Yes I have. I tried both i2c SDA and SDL pins 0 and 1, and both commands i2cdetect 0 or 1.
- 105 Announcements & News
- 185 Welcome Developers!
- 48 Tech Updates
- 693 UP Products
- 11 UP 7000
- 10 UP Xtreme i12
- 11 UP Squared Pro 7000
- 19 UP Squared V2
- 59 UP 4000
- 35 UP Squared 6000
- 60 UP Squared Pro
- 143 UP Xtreme
- 837 UP Squared
- 222 UP Core
