kernel warnings
hi there,
on boot i get the following messages:
not sure if this is problematic, system seems to work ok so far
[ 1.506769] Failed to find cpu0 device node
[ 2.750257] i801_smbus 0000:00:1f.1: Failed to allocate irq -2147483648: -107
from dmesg:
[ 1.506575] Linux agpgart interface v0.103
[ 1.506709] AMD IOMMUv2 driver by Joerg Roedel [email protected]
[ 1.506710] AMD IOMMUv2 functionality not available on this system
[ 1.507093] Unable to detect cache hierarchy from DT for CPU 0
[ 2.749958] mmc1: SDHCI controller on PCI [0000:00:1e.0] using ADMA 64-bit
[ 2.750204] i801_smbus 0000:00:1f.1: can't derive routing for PCI INT A
[ 2.750207] i801_smbus 0000:00:1f.1: PCI INT A: not connected
[ 2.750233] i801_smbus 0000:00:1f.1: SPD Write Disable is set
[ 2.750707] i801_smbus 0000:00:1f.1: SMBus using polling
greets,
Rob
Best Answer
Hi Rob, thanks for your report and sorry for the belated response.
The messages are harmless and don't indicate any actual issue with your board:
@Rob said:
[ 1.506769] Failed to find cpu0 device nodeThis is printed because the ubilinux kernel enables CONFIG_OF and yet the board provides hardware information through ACPI instead of DeviceTree.
This message was always printed on Apollo Lake systems. This was only fixed recently - see https://patchwork.ozlabs.org/patch/840384/
Thanks!
this is for the up2 N3350 running ubilinux 4.0, bios upgraded to 2.1
- 300 All Categories
- 50 Product News - New Product/Product Change Notice/ End-of-life
- 184 Welcome Developers!
- 24 Tech Updates
- 521 UP Products
- UP Xtreme i12
- UP Squared Pro 7000
- UP Element i12 Edge
- 6 UP Squared V2
- 17 UP 4000
- 23 UP Xtreme i11
- 44 UP Squared Pro
- 139 UP Xtreme
- 813 UP Squared
- 88 UP Core Plus
- 221 UP Core
- 43 UP AI Edge
