UART0 no keyboard input
Gilmar
New Member Posts: 18 ✭
Has anyone tried booting the up board with UART0 only?
I tried it using FT232 usb-uart converter then some jumper wires into pin 9 & 10 of CN7 and of course the GND. The terminal I used was Teraterm but I don't think it matters. It display the GRUB but when login displayed it doesn't accept any input from keyboard.
I tested my FT232 converter TX-to-RX connection to see if input from keyboard is reflected back to terminal, it did work, so my FT232 is working fine.
Is there something I need to do in BIOS or wherever it is to be able to write to terminal?
I also enabled the COM0- console redirection in BIOS. Without it enabled, I have to connect first the HDMI display before the console terminal got some text on it.
It's a bit confusing the instruction found at https://up-community.org/wiki/Serial_console it says:
1. CN7 is 10-pin connector, but they don't provide 10-pin adapter.
2. They provide CN7 adapter to serial + USB 2.0 in UP SHOP, but they don't indicate how to connect it, looking at the picture it doesn't seem a 10-pin adapter.
3. They indicate FTDI (serial to USB) cable, but they don't mention about USB-UART converter, how to connect the FTDI cable then, does it fit on CN7? And no indication if the up board has on-board usb-serial converter already, customer should figure it out, remove the heat sink and find some chip that indicate "232" thing. Specification is incomplete and no schematic to look at.
Hi gilmar,
Could you please post the BIOS version shown in the main BIOS menu? It sounds like yours is older than the BIOS used to test the steps.
(In pre-production versions, COM0 redirection wasn't enabled by default and UART0 RX was known not to work yet, which is exactly your current situation.)
As for the CN7 adapter from the shop, the 3-pin connector brings out UART0 RX/TX and GND from the 10-pin connector, which map directly to three pins on a FTDI cable. I will update the guide shortly adding detail.
Again, many thanks for your feedback! -
Hi jarteaga,
Thank you for your reply.
I'm not sure what particular version I will look at, but I'll give you some.
This is the BIOS information:
Core Version : 5.011
Project Version: UPC1B 0.50 x64
Build Date and Time: 04/151/2016 18:19:56
Version 2.17.1249 before the Copyright written at the very bottom of the bios display.
thanks -
Thank you.
From Linux, could you please also post the output for this command?cat /sys/devices/virtual/dmi/id/bios_version
With that as well, I should be able to bring this up with the BIOS team.
EDIT: the guide has now been updated with details on the UART0 wiring:
Serial_console#Using_the_provided_adapter
Thanks! -
Here is the result of the command:
UPC1BM0Lcat /sys/devices/virtual/dmi/id/board_version
V0.4
Thanks -
Any update on how I can make this thing work?
Also, does the USB 2.0 pin header has a 10-pin header on it? I can't actually see the end of the cable in the picture if it has a 10-pin header.
If I'm going to purchase 1 up-board from your shop, can I expect the UART0 is working?
Thanks -
Hi gilmar,gilmar wrote:Any update on how I can make this thing work?gilmar wrote:Also, does the USB 2.0 pin header has a 10-pin header on it? I can't actually see the end of the cable in the picture if it has a 10-pin header.
Serial_console#Using_the_provided_adapter.gilmar wrote:If I'm going to purchase 1 up-board from your shop, can I expect the UART0 is working?
- 105 Announcements & News
- 186 Welcome Developers!
- 50 Tech Updates
- 693 UP Products
- 11 UP 7000
- 10 UP Xtreme i12
- 11 UP Squared Pro 7000
- 19 UP Squared V2
- 59 UP 4000
- 35 UP Squared 6000
- 60 UP Squared Pro
- 143 UP Xtreme
- 837 UP Squared
- 222 UP Core
