SATA Hotplug / Hotswap available
Hi guys!
Is it possible to add / remove a sata drive after booting the up²? My project may use a 3.5" SATA HDD, whoom power (12V, 5V) shall be activated after the up² has bootet (MOSFET via GPIO). GND of cause is connected from beginning.
Yes, you can enable hot swap on the SATA-port in BIOS.
