Disable UART0 debugging
Fredrick
Fredrick New Member Posts: 3
Is it possible to use UART0 for any other purposes other than debugging? Can I use UART0 to talk to other uart devices?
    The UART0 is a normal UART which can be used also for debugging (e.g. you can boot into the BIOS menu, perform a linux installation, etc.), but not only.
    On ubilinux 4.0 is set as a terminal console but you can easily disable it.
  • Fredrick
    That's great, would you happen to know how I can disable it.
  • XuluMulu
    XuluMulu New Member Posts: 2
    Can you elaborate on how to do this as I have tried to and have not been successful on an UP core board running ubilinux.
  • abhishekgoudar
    abhishekgoudar New Member Posts: 1
    Any updates on this ? Was anybody able to get UART0 running ?
    Hi @abhishekgoudar
    If you are using ubilinux, it is not a supported distribution anymore.
    I would suggest to move to one of the supported option (Ubuntu 16.04/18.04 or Yocto if you need more customization and you want to build your own distribution).
