I2C and Windows 10, is there any way to do it?
Heretical Coward
Heretical Coward New Member Posts: 3 ✭
Hi, I am currently searching for a way to use the GPIO of the Up Board to communicate via I2C using Windows 10.
Ive come across the issue detailed in many other forum posts .
Since those posts are largely over 6 months old, I would like a more recent answer on wether this is/will be possible.
  • Philipp Sojer
    Philipp Sojer New Member Posts: 2 ✭
    We also need a solution for I2C under Windows 10!!
    Does someone know the i2c chip?
  • Philipp Sojer
    We also need a solution for I2C under Windows 10!!!
    Does anyone know the I2C chip?
  • NoelStephens
    NoelStephens New Member Posts: 25 ✭
    As far as I know, I2C is completely broken under normal versions of Windows 10.
    This has been a *very* long awaited fix, and is speculated that it is either due to the drivers =or= the BIOS. However, since I2C works under all iterations of supported Linux, my best guess is that there is something wrong with the AAEON Windows library.
    Just started downloading the 64 bit version of Windows IoT Core and will let you know if that works.
