clonezilla and ubilinux iustall
wintns
Posts: 11 ✭
Good morning.
During the process of creating and restoring backups using clonezilla, emmc is not aware of the damage or what is wrong with it.
Do try to reinstall ubilinux to try it again from scratch.
I can not use emmc as an error message. Anyone please help me.
Hi
can you describe better what you've done/what happened?
those message are from Ubilinux or from clonezilla?
Have you restored properly the partition?
Regards
Nicola Lunghi -
I'm sorry. I feel English difficult because I am Korean. The first time I used clonzilla to back up to USB, I tried to restore it again, but I was still unsuccessful because of the error. After that I felt that something was wrong. I installed boot again to install ubilinux, connected usb and installed ubilinux. Well done.
However, after the username, domain, and write, the process stops searching for partitions. The above picture is an error that appears after selecting install after ubilinux installation boot. -
Hi
It was an error in the installer or when the system boot?
Regards
Nicola Lunghi -
There is no error message when booting the system.
Installing ubilinux Boot up There are no errors until install, install (console mode?). However, during the installation process error fsyncing / closing mmcblk0p1, mmcblk0p2, mmcblk0p3 input / output occurs -
Hi
Please try to reinstall again
Regards
Nicola Lunghi -
I have tried to reinstall ubilinux more than 10 times already.
Please help me.
When I installed Ubilinux for the first time, I did not get any error like this.
Back up partitions Is there anything else I need to do to reinstall os on a partition after an error during the recovery process? And the BIOS does not show mmc in the boot options. -
Hi
try this:
[ol]
[li]Boot from the ubilinux install cd
[li]Select the option for non automatic install
[li]when the installer script start press Ctrl-c
[li]post here the output of the commands:
[ul]
[li]parted -l[/li]
[li]lsblk[/li]
[/ul]
[/li]
[/ol] -
This error occurs during the disk partitioning step.
Oh .. I used version 3.0 before.
I get an error when trying to install again with version 4.0.
And the result of the 'parted -l', 'lsblk' command.
and 'fdisk / dev / mmcblk0' generates 'can not open / dev / mmcblk0p1: input / output error'. -
Hi
from the screenshot that you send me seems that you have interrupted the automatic install
please di the following:
1) select ubilinux INSTALLER Interactive option at boot (see here https://up-community.org/wiki/Ubilinux#Installation )
2) interrupt the installer script when it's asking question
3) try to give me the result of this:
(reload the partition from disk)
blockdev --rereadpt
parted -l
lsblk
ls /dev/mmc*
Also you can try
dmesg -H
and see if there are errors relative to the disk
Another thing you can do is a try a regular Ubuntu/Debian install and see if you install the system correctly
Best Regards
Nicola Lunghi -
dmesg -H result
and then install error continue...:(
blk_update_request i/o error mmcblk0 ...
parted -l result
Is it a hardware problem? I have never touched it. -
Hi
I notice that you were using an old BIOS please update then try again.
https://up-community.org/downloads/category/18-uefi_bios
Try again to install another distro (Ubuntu would be perfect)
If you cannot install neither Ubuntu then probably you board is damaged
In that case contact directly AAEON for support/replacement https://up-shop.org/content/5-cancellation-and-return-policy
Regards
Nicola Lunghi
