Hi-Safe Error FFFFF0FF
Drew
New Member Posts: 6
I’m attempting to configure the GPIO pins on the 40-pin HAT connector from within Windows 10 x64. I’m not having much luck, though I can change the GPIO Output Levels successfully in the BIOS. This is an Up2 Pentium n4200.
When I try to run Hi-Safe, I get the Unable to load error, with code FFFFF0FF reported. If I try to run the example apps with the SDK, I also get this code at the lib initialization call.
Is there anyway to get past this?
Hi, did you solve your problem with Hi-Safe? I get the same errors and can't fix them regardless of the version of Hi-Safe I am running.
To set the GPIOs outside the BIOS you can use the DIO sample from the SDK. Have you tried that?
- 105 Announcements & News
- 186 Welcome Developers!
- 50 Tech Updates
- 693 UP Products
- 11 UP 7000
- 10 UP Xtreme i12
- 11 UP Squared Pro 7000
- 19 UP Squared V2
- 59 UP 4000
- 35 UP Squared 6000
- 60 UP Squared Pro
- 143 UP Xtreme
- 837 UP Squared
- 222 UP Core
