Running Debian Server
Pieter Groeneweg
New Member Posts: 6 ✭
Like it is possible to have Ubuntu running on an up/board,
https://up-community.org/wiki/Ubuntu
Is it also possible to do the same trick with a clean Debian install? Ubuntu being a derivate of Debian and so is Ubilinux.
Would it make a difference what Debian version I use? Jessie or the new Stretch?
Tx,
Tx,
Dear pieter
we just pre-released last Friday to the Innovators the release 4 of Ubilinux that is based on Debian Stretch.
If no major problems occur we will release it on the website at the beginning of the next week.
So I suggest you to wait for it.
This release will support UP1 and UP^2.
Best Regards
Nicola Lunghi -
Hi Nicola,
Would that come with the choice between a desktop and server install? If so I may wait.
When I installed Ubilinux previously, it came as a desktop linux version. I do not need that, hence my question.
Tx,
Pieter -
Hi pieter
You can install a regular Debian Stretch server and add the Ubilinux 4 repository.
DISCLAIMER: this is not a tested procedure, so do at your risk
To add our packages to a Debian installation do this:
1. Download a Debian Stretch image with firmware for the UP NICs:
Debian Stretch firmware image
2. install it
3. Install necessary packagessudo apt-get update & sudo apt-get install software-properties-common apt-transport-https
4. add the Ubilinux repository gpg keywget -qO - https://ubilinux.org/ubilinux.gpg.key | sudo apt-key add -
5. add the Ubilinux apt repository to /etc/apt/sources.listdeb https://ubilinux.org/ubilinux dolcetto main deb-src https://ubilinux.org/ubilinux dolcetto main
6. Update the repository listsudo apt-get update
7. install the firmware and kernel and libraries packages for Up/Up^2sudo apt-get install firmware-ampak-ap6214a/dolcetto firmware-intel-sound firmware-iwlwifi firmware-linux-nonfree firmware-realtek base-files/dolcetto linux-headers-ubilinux-amd64/dolcetto linux-image-ubilinux-amd64/dolcetto mraa/dolcetto python-rpi.gpio/dolcetto upm/dolcetto ubilinux-extras/dolcetto
7. remove the default linux kernelsudo apt-get autoremove --yes --purge '^linux-image-.*[^x]-amd64$'
Hi Nicola,
Thanks you very much for your reply. I will try this and I will let you know if it worked!
Tx,
Pieter -
Hi
please test it and if all works we can add it to the wiki also for other users.
Nicola -
Hi Nicola,
As I will be using the UP as a server, I will not be using sound and the pins.. Would there be some way to test if they work ok by any other means than connect anything to it?
The only thing I have to fit to the pins is a UPS hat for a PI3.
https://shop.olmatic.de/en/ups-raspberry-pi/1-susv-pi-basic-4260434190012.html
Tx,
Pieter -
Hi
you can play with the led on /sys/class/leds/upboard* and see if you can turn it on on and off (all command executed as root)echo 255 > /sys/class/leds/upboard\:red\:/brightness echo 0 > /sys/class/leds/upboard\:red\:/brightness
You can also check if you can see the up pincontroller device withcat /sys/kernel/debug/pinctrl/up*/pins
I don't know the UPS hat that you have.
I've looked at the driver but is a compiled binary so I cannot check if its compatible with this kernel version.
Regards
Nicola Lunghi -
Hi Nicola,
After step 3 I had error: gpg: no valid OpenPGP data found.
I needed to install these first:
sudo apt-get install apt-transport-https
Then I could continue.
Check for registered pins: 28
pin 0 (I2C0_SDA)
pin 1 (I2C0_SCL)
pin 2 (I2C1_SDA)
pin 3 (I2C1_SCL)
pin 4 (GPIO4)
pin 5 (GPIO5)
pin 6 (GPIO6)
pin 7 (SPI_CS1)
pin 8 (SPI_CS0)
pin 9 (SPI_MISO)
pin 10 (SPI_MOSI)
pin 11 (SPI_CLK)
pin 12 (PWM0)
pin 13 (PWM1)
pin 14 (UART1_TX)
pin 15 (UART1_RX)
pin 16 (GPIO16)
pin 17 (GPIO17)
pin 18 (I2S_CLK)
pin 19 (I2S_FRM)
pin 20 (I2S_DIN)
pin 21 (I2S_DOUT)
pin 22 (GPIO22)
pin 23 (GPIO23)
pin 24 (GPIO24)
pin 25 (GPIO25)
pin 26 (GPIO26)
pin 27 (GPIO27)
The leds
All could be turned on and off.
One thing though, when I uname -a, it shows no debian anymore.. just generic linux.
Installers that verify the OS (for debian/Ubuntu, Centos/RHEL) break on that.
Tx,
Pieter -
Many Thanks pieter
we will check the issue with the kernel name
Regards
Nicola Lunghi -
So would I be able to install openmediavault 3 on UP Squared?
Dear ckykenken
Open media Vault seems to be based on Debian 8.
There's nothing preventing you to install it on the UP^2 (is an x86 board) as long as you don't need the feature of our 4.9 kernel (most notably the GPIO support and various bug fixes)
If they release OMV 4.0 (that should be based on stretch) then you can install our ubilinux distribution (based on Debian stretch) and add the OMV apt on top of it.
You could also try to install our kernel on top of the Debian 8 (but its not tested so you are on your own)
Best Regards
Nicola Lunghi
- 105 Announcements & News
- 186 Welcome Developers!
- 50 Tech Updates
- 693 UP Products
- 11 UP 7000
- 10 UP Xtreme i12
- 11 UP Squared Pro 7000
- 19 UP Squared V2
- 59 UP 4000
- 35 UP Squared 6000
- 60 UP Squared Pro
- 143 UP Xtreme
- 837 UP Squared
- 222 UP Core
