UAS Support on UP Squared
Xinghc
Xinghc
edited September 2017 in UP Squared Linux
I have visited the wiki page of the specification of UP Squared board, but still not found any description about UAS (USB Attached SCSI). In my quick test, it seems that UAS is not working on this board (I am using Lubuntu 16.04).
Does UP Squared support UAS?
Xinghc
  • Hi xinghc,
    UAS driver was disabled for UP Board due to a bug with the USB driver but this shouldn't apply to UP Squared.
    What kernel version is installed on your Ubuntu ( $ uname -r )?
    UAS depends not only on the Operating system support but also on the USB3.0 to SATA bridge chip used by your external disk/adapter.
    Could you check if the same configuration is working on a different computer with the same operating system?
