USB3.0 OTG port in device mode
Does the UP Squared support USB3.0 OTG port in device mode? Wiki [1] says it supports only on UP , so I am just wondering what's the status on UP Squared.
[1] https://up-community.org/wiki/Serial_console#USB3.0_OTG_port_in_device_mode
Hi nagineni
We and the bios team are currently working on it it should be enabled in next bios/ubilinux release.
Regards
Nicola Lunghi -
Thank you for quick response, Nicola!
When can we expect the next BIOS release? -
Hi nagineni,
We should release the next BIOS in a week or so. -
Thanks for the update, dcleri!
Hi, can you please confirm that current version of Up Squared is supporting USB OTG device mode ?
I'm interested in impersonating USB storage device and/or HID devices in Ubuntu.Thank you.
Hi raresh_p,
USB OTG should be supported on UP2 from BIOS V2.1 onwards. See:
https://wiki.up-community.org/Serial_console#UP_Squared -
Thank you for your comment, based on this I have ordered an UP Board.
While in basic tests seemed to work with memtest ISOs (mounting it then having it available as USB Flash on Win 10 laptop) , now I have the "UDC error" :
udc-core: couldn't find an available UDC - added [g_mass_storage] to list of pending driversIs there any description how to specifically debug this and even check if the hardware is working ok?
Or even how the BIOS setting should look in order to use UP Board as USB Device ?PS: Forgot to mention, I have the UP Board version with 2Gb memory and 16GB eMMC disk.
Thank you.
Hi @raresh_p ,
Did you get that error when you connect your UP to your PC via USB OTG port, right?
To be sure your OTG is working you must check in your PC if the board is available.
Use dmesg | tail for example.
You should see something like that:[48794.482725] usb 2-2: Manufacturer: Intel
[48794.482729] usb 2-2: SerialNumber: 012345678
[48794.484283] cdc_acm 2-2:1.0: ttyACM0: USB ACM device
[48845.288162] usb 2-2: USB disconnect, device number 33
[48852.476676] usb 2-2: new high-speed USB device number 34 using xhci_hcd
[48852.626517] usb 2-2: New USB device found, idVendor=0525, idProduct=a4a7
[48852.626524] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[48852.626529] usb 2-2: Product: Gadget Serial v2.4
[48852.626533] usb 2-2: Manufacturer: Linux 4.9.88-ubilinux+ with dwc3-gadget
[48852.627912] cdc_acm 2-2:2.0: ttyACM0: USB ACM device -
Hello ,
I have the Up squared 8GB memory / 64 GB storage version.Problem: Windows 10 shows "Device malfunction, Could not recognize" when plugged in the Up squared board through otg.
Steps: Following steps are performed to use up-squared as gadget mass storage device and to access it from windows 10
1 In bios the OTG device mode is already enabled.
2 In terminal , I ran following commands,
dd bs=1M count=4 if=/dev/zero of=gadget_storage
fdisk -u gadget_storage
* pressed "x" for expert mode
* pressed "s" and entered 8 for 8 sectors
* pressed "h" and entered 1 for 1 head
* pressed "c" and entered 1024 for 1024 cylinders
* pressed "r" to get out of xpert mode
* pressed "n" and then "p" for primary
* Entered the default value to select the partitions and then First sector and Last sectors
* pressed "t" and and pressed "7" to select file system as NTFS
* pressed "w" to save the partition table.
losetup -o512 /dev/loop0 gadget_storage
*// -o 512 setting the byte offset (First sector number[1 in my case] * 512 = 512)
mkfs.ntfs -p 1 -S 8 -H 1 /dev/loop0 8191
*// p sets starting sector number which is 1 , S represent sectors per track which i selected as 8 , H as heads and 8191
*// reperesent total sectors .
losetup -d /dev/loop0
*// detaching the backing store file from loop device
modprobe g_mass_storage stall=0 file=gadget_storage- Connected the upsquared to windows 10 host machine while OTG cable
Problem : windows 10 shows , Device malfunctioned , could not recognize the usb device.
However , I could successfully detect the mass storage in windows 7 and linux ubuntu host systems ,
Could somebody please help me understand what could go wrong with windows 10.
Thank you
Hi @vini_gajjar ,
Please, if you have any issue with Windows OS, please you must open a discussion in Windows area for UPSquared:
https://forum.up-community.org/categories/up-squared-windows
- 105 Announcements & News
- 185 Welcome Developers!
- 48 Tech Updates
- 693 UP Products
- 11 UP 7000
- 10 UP Xtreme i12
- 11 UP Squared Pro 7000
- 19 UP Squared V2
- 59 UP 4000
- 35 UP Squared 6000
- 60 UP Squared Pro
- 143 UP Xtreme
- 837 UP Squared
- 222 UP Core
