Event 10016 DistributedCOM crashing Windows 10
Over the last couple of days I have experienced multiple crashes of my Up2 / Win 10 due to an 10016 DistributedCOM error. The system shuts down - no blue screen, just goes black. Each time I have difficulty restarting due to repeated crashes during restart. I have found that removing the DP connection allows the machine to restart successfully on the next try (I am using both an HDMI display and a second HDMI monitor via a DP to HDMI active converter). I also experienced, after system reboot, that Windows immediately crashed when I plugged in the DP adapter. After a couple of repair / reboot cycles, I could not use the DP. The direct HDMI display works fine. This further suggests that the problem is related to DP drivers.
Here is the detail from Event Viewer:
Log Name: System
Source: Microsoft-Windows-DistributedCOM
Date: 8/2/2017 2:18:45 PM
Event ID: 10016
Task Category: None
Level: Error
Keywords: Classic
User: LOCAL SERVICE
Computer: Up2
Description:
The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID {6B3B8D23-FA8D-40B9-8DBD-B950333E2C52} and APPID {4839DDB7-58C2-48F5-8283-E1D1807D0D7D} to the user NT AUTHORITY\LOCAL SERVICE SID (S-1-5-19) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-DistributedCOM" Guid="{1B562E86-B7AA-4131-BADC-B6F3A001407E}" EventSourceName="DCOM" />
<EventID Qualifiers="0">10016</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x8080000000000000</Keywords>
<TimeCreated SystemTime="2017-08-02T18:18:45.705970900Z" />
<EventRecordID>7961</EventRecordID>
<Correlation />
<Execution ProcessID="836" ThreadID="1248" />
<Channel>System</Channel>
<Computer>Up2</Computer>
<Security UserID="S-1-5-19" />
</System>
<EventData>
<Data Name="param1">application-specific</Data>
<Data Name="param2">Local</Data>
<Data Name="param3">Activation</Data>
<Data Name="param4">{6B3B8D23-FA8D-40B9-8DBD-B950333E2C52}</Data>
<Data Name="param5">{4839DDB7-58C2-48F5-8283-E1D1807D0D7D}</Data>
<Data Name="param6">NT AUTHORITY</Data>
<Data Name="param7">LOCAL SERVICE</Data>
<Data Name="param8">S-1-5-19</Data>
<Data Name="param9">LocalHost (Using LRPC)</Data>
<Data Name="param10">Unavailable</Data>
<Data Name="param11">Unavailable</Data>
</EventData>
</Event>
This discussion seems promising: https://support.microsoft.com/en-us/kb/899965. I followed the link posted by DarekWa. The Microsoft article was written for XP, so I had to translate to Win10. When I got to the dcomcnfg part of the process, a couple of dialogues popped up indicating that the offending application was not recorded; and asking if I wanted to record it. I responded yes to both, although that isn't mentioned in the posts. The offending application is ShellServiceHost in my case. If your Security tab is greyed out in dcomcnfg, look carefully at the second page of the postings. You may need to give administrators full_control permissions to the key in the registry before proceeding to dcomcnfg. You may also need to change ownership of the application/key. In my case it was set to TrustedInstaller. I changed it to Administrators. Note this assumes your account is a member of Administrators. Don't forget to reboot after making registry changes.
R
Log Name: System
Event ID: 10016
Task Category: None
Level: Error
Keywords: Classic
User: LOCAL SERVICE
Computer: Up2
Description:
Event Xml:
<System>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Correlation />
</System>
<EventData>
</EventData>
</Event>
R
After checking permissions / completing the steps to the first-mentioned posts, my Up2 rebooted successfully and did not crash when I connected the second monitor via DP.
Has anyone else experienced problems with crashing / displays / DP or DP adapters?
Unrelated to this issue, I bought a 5v 6A power supply from Up-store to replace the 5v 4A supply that ships with Up2. I had seen enough recommendations for 6A on the forum that this seemed like a sound course of action. The crashing behavior has not occurred since switching to the 6A supply.
Association of crashes with 10016 was based on occurrence in the logs. I inferred causality - now, I believe, erroneously. I suspect that the total load of DP driving a monitor, HDMI driving a monitor, the HDMI monitor being powered from a USB port on the Up2 (it's a portable HDMI flat panel touch screen), WiFi / BT4 and (frequently) a secondary WiFi dongle ran the Up2 too close to the supply limit for the 4A supply. Crashes often seemed to follow complex operations that involved both displays; or other work-intensive activities. Power demand increases with CPU and GPU load, probably pushing my configuration over the 4A line. Note that I still see 10016 errors in the logs at about the same rate and for the same applications / registry keys as before - now without crashing.
If my conclusion is correct, it would be advisable to ship the Up2 with a 6A power supply by default. The cost difference between the 4A and 6A bricks likely is minimal. Downside that the beefier supply would prevent: customers chasing intermittent hardware or software problems with the Up2. Market perception of product problems, however erroneously based, is more costly than the few cents per power supply difference. And my guess is that a sizeable percentage of the Up customer base works with more demanding configurations.
I was under the (perhaps mistaken) impression that any boards pre-orders placed after the campaign had finished did not include a power supply, and that it was up to the customer to order a 6A one from the Shop if they didn't already have one available.
I hope you have managed to solve your problem though!
