Plex server can play 4K video with the Use hardware acceleration when available
Raymond Day
Raymond Day New Member Posts: 67 ✭
Wow I am very impressed with this. Have plex media server on it and I just did the Lifetime plex pass for about $120. That way it let me download the Plex that can do hardware acceleration when available (Experimental) and wow it works super good on this Up squared board. I even played a 4K video on my Dad's 4K TV. The video is only 22 FPS but it played very good.
I even tested playing on my cell phone away from home and it plays the videos real good too over the cell network from my home.
Got a 500GB on the SATA port on the Up Squared board. Very impress that it can play videos like this. I have the Ubuntu desktop on it that they had here to download. But I am just using it like a server. I don't even have the HDMI plug in it. But they did not have a server ISO to put on here. I guess it even work better if just a server not a desktop.
-Raymond Day
  • Duane Goodman
    Duane Goodman New Member Posts: 33 ✭
    edited July 2017
    Theoretically the board should support 4K media at up to 60 FPS if you have the N4200 chip version. That's actually the main reason I bought it vs a UDOO x86. I have however seen examples of both boards playing 4K 60 FPS media.
    For max performance you need to use the display port interface as it supports both a higher resolution and refresh rate:
    Max HDMI Res 3840x2160 @30 Hz
    Max DP Res 4096x2160 @60 Hz
    Source: Intel N4200
