Successfully installed Ubuntu 17.04
Mialaret
Mialaret New Member Posts: 33 ✭
I sucessfully installed Ubuntu 17.04 on the Up Square.
Note that it is only for use as a desktop computer, as we need drivers / kernel from Emutex/Aaeon to be able to use the 40 pin I/O and the FPGA, none of which are available at the present time.
I set the system so that Ubuntu & Windows 10 are 100 % independent:
- Windows 10 has been installed on an mSata SSD (Samsung Evo 850 mSata).
- An image of Ubuntu Desktop 17.04 iso file has been downloaded from Canonical and copied on an USB drive with Rufus.
- Up Square is booted to this USB drive
- Within Ubuntu Setup, I chose the last option of the ubiquity installer, 'Something else'
I created a 256 MB UEFI partifion on the eMMC drive, as well as a standard ext4 partition with '/' mountpoint for the Ubuntu. I did not create a swap partition since 17.04 can use a swap file.
- I installed the bootloarder on the UEFI partition and the rest of Ubuntu of the standard partition.
- The bootloader automatically detects Windows on the hard drive and adds it to the boot menu.
The advantage of such a setup is that I can reformat the eMMC and windows will continue to work just fine, at the most I'll have to change the boot drive in the UEFI.
Converserly, I could reformat the SSD and Ubuntu would still work fine.
