IoT Starter Kit based on UP board
Ivona Spurná
Ivona Spurná New Member Posts: 2 ✭
In cooperation with AAEON we have prepared IoT Starter Kit for easy development of wireless IoT applications.
http://www.iqrfalliance.org/product/iot-starter-kit
Content
DS-IOT-01
[ul]
[li]IQRF set for wireless connectivity
[ul]
[li]Sensor kit DDC-SE-01 is intended to measure temperature, light intensity and voltage selected by the potentiometer.
Relay kit DDC-RE-01 enables to switch connected equipment on/off using two relays inside.
These kits are controlled by DPA commands implemented in Custom DPA handlers delivered with the set. The handlers specify HWP identification (HWPID) to individual kits which allows their identification.
DS-IOT-01 devices can be connected via the adapter to the UP board and then to any cloud. The gateway as well as the cloud can be adapted for communication with IQRF devices utilizing their HWPIDs.
[/li]
[li][/li]
[/ul]
[/li]
[/ul]
Components
[ul]
[li]4 x DCTR-72DAT – IQRF transceiver
CK-USB-04A – IQRF programmer and debugger
3 x DK-EVAL-04A – Universal portable development kit for TR modules
DDC-SE-01 – IQRF evaluation and development kit
DDC-RE-01 – IQRF evaluation and development kit
KON-RASP-01 – Adapter to connect IQRF transceiver to UP board
CAB-USBABMICRO – Micro USB cable 18.5 cm
USB flash drive – Software and documentation (including HWPs and Custom DPA handlers)
[/li]
[/ul]
UP board 2GB + 32 GB eMMC memory (e-shop)
The 40 Pin I/O connector, the USB 3.0 OTG, the Gigabit Ethernet, the HDMI and more other features make it a perfect solution for different domains and products like Robotics, Drone, Machine Vision, Smart Home, Education, Digital Signage, Intelligent Cars, Internet Of Things. The compatibility with Linux, Android, and all the Windows 10 distributions give you great flexibility, scalability and quick time to market.
Power supply
Architecture
UP board is connected to the IQRF network via SPI interface (adapter) or via CDC interface (GW-USB/CK-USB).
You can find installation steps in documentation on https://github.com/iqrfsdk/iot-starter-kit.
There is the IQRF Daemon prepared for easy communication between IQRF network and other platforms. Follow the steps to install it to UP.
IQRF Daemon has several communication channels (UDP, MQTT, MQ) allowing it to be easily connected to a 3rd party local or remote services and applications (e.g. Microsoft Azure, Node-RED Dashboard, remote control from RehiveTech etc.).
You can also connect to your IQRF network ready HW extensions as sensors and actuators.
