Running the script at startup FAILED
bruce
New Member Posts: 15
I have a script which includes the operations of GPIOs, Sensors, USB flash drive.
The script runs perfectly when I execute it using the terminal. Now I want to launch the script at start up because I want to use the system as a portable device.
so, I wrote a test script to check whether it is working or not (on startup).
I specify the path in
So, next time I changed the path to the script which includes the operations of sensors/USB/gpios
But it is not working anymore, the same code runs using the terminal but not while start up. Please helep
import RPi.GPIO as GPIO import time GPIO.setmode(GPIO.BCM) GPIO.setwarnings(False) GPIO.setup(3,GPIO.OUT) GPIO.setup(4,GPIO.OUT) GPIO.setup(27,GPIO.OUT) GPIO.setup(17,GPIO.IN) while True: input_value = GPIO.input(17) GPIO.output(27,GPIO.HIGH) if input_value == False: GPIO.output(27,GPIO.LOW) GPIO.output(3,GPIO.HIGH) time.sleep(5) GPIO.output(3,GPIO.LOW) GPIO.output(4,GPIO.HIGH) time.sleep(5) GPIO.output(4,GPIO.LOW) while input_value == False: input_value = GPIO.input(17)
/etc/rc.localto launch this simple code at start up
sudo python /home/myUPboard/myProject/test.py exit 0
- 301 All Categories
- 184 Welcome Developers!
- 24 Tech Updates
- 548 UP Products
- 1 UP Xtreme i12
- UP Squared Pro 7000
- 10 UP Squared V2
- 25 UP 4000
- 44 UP Squared Pro
- 140 UP Xtreme
- 819 UP Squared
- 221 UP Core
- 43 UP AI Edge
