Raspberry Pi LCD
Gregory L Holloway
New Member Posts: 4 ✭
in Peripherals
Is the UP compatible with the raspberry pi 7" touch screen?
https://www.raspberrypi.org/blog/the-eagerly-awaited-raspberry-pi-display/
The UP isn't compatible with the Raspberry Pi screen that you mentioned. However, an industrial-grade 7" touch screen will be made available from the UP shop:
http://up-shop.org/up-board-chassis-peripherals/11-lcd-touchscreen-display-kit-10.html -
Yes I have seen that. Is there a data sheet with dimensions?
Regards
Greg -
Even just a rough size for the two screens would be a help, I have a specific build space and I need to know if the 10" lcd will fit.
