cryptsetup benchmark
elatllat
New Member Posts: 9 ✭
Please post your up board. cryptsetup benchmark results.
sudo -i apt-get -y install cryptsetup && cryptsetup benchmark uname -a; cat /etc/*release /etc/*version
no one?
Your chances of someone using this benchmark and posting here may be bigger after people have actually got their UP.
How long is the wait currently, from buying to recieving? (or I suppose how long have people been waiting?)
I would have thought Aaeon Europe and Emutex woud be active in there own forms and they have had prototypes for like 8 months. Bad support if it's community only and no official mods on the forms.LennStar wrote:Your chances of someone using this benchmark and posting here may be bigger after people have actually got their UP. -
Hi elatllat,
Apologies for this post slipping through. We do intend to post detailed performance metrics shortly. For accuracy, we prefer publishing only results for the final revision, that only went into production (and shipment) recently.
(In the meantime, just to give you a *very* rough idea: the CPU does support AES-NI. For full disk encryption usecases, for example, you can expect AES-512-XTS encryption/decryption performances no lower than 200 MiB/s.) -
Thanks for the answer. If that number is similar to the aes-cbc of the test it does sound like an improvement over the ARM SBC I'm using.
http://forum.odroid.com/viewtopic.php?f=95&t=15574&p=101808&hilit=cryptsetup#p101808 -
Any chance someone can post this benchmark before the UP is replaced with the UP^2?.
Hi Elatlatt,
Cryptsetup 1.6.6 on ubuntu 16.04 with UP Board 4.4 Kernel (without any kernel/governor optimization) shows these results:# Tests are approximate using memory only (no storage IO). PBKDF2-sha1 258015 iterations per second PBKDF2-sha256 168907 iterations per second PBKDF2-sha512 102400 iterations per second PBKDF2-ripemd160 196215 iterations per second PBKDF2-whirlpool 43115 iterations per second # Algorithm | Key | Encryption | Decryption aes-cbc 128b 216.9 MiB/s 312.0 MiB/s serpent-cbc 128b 24.7 MiB/s 71.1 MiB/s twofish-cbc 128b 57.3 MiB/s 65.6 MiB/s aes-cbc 256b 172.0 MiB/s 245.0 MiB/s serpent-cbc 256b 27.6 MiB/s 71.1 MiB/s twofish-cbc 256b 62.6 MiB/s 65.5 MiB/s aes-xts 256b 271.1 MiB/s 274.8 MiB/s serpent-xts 256b 65.8 MiB/s 66.7 MiB/s twofish-xts 256b 61.1 MiB/s 61.0 MiB/s aes-xts 512b 219.8 MiB/s 221.2 MiB/s serpent-xts 512b 67.2 MiB/s 66.7 MiB/s twofish-xts 512b 61.1 MiB/s 61.0 MiB/s
while playing with the UP2, I am getting some really interesting results... stay tuned for the next episode!
Thanks for the benchmark, I expect the up^2 is about the same speed (assuming it's cpu options all have the same aes)?
Hi elatllat,
The results are a bit different...# Tests are approximate using memory only (no storage IO). PBKDF2-sha1 572366 iterations per second for 256-bit key PBKDF2-sha256 736359 iterations per second for 256-bit key PBKDF2-sha512 520126 iterations per second for 256-bit key PBKDF2-ripemd160 439838 iterations per second for 256-bit key PBKDF2-whirlpool 254015 iterations per second for 256-bit key # Algorithm | Key | Encryption | Decryption aes-cbc 128b 377.3 MiB/s 914.7 MiB/s serpent-cbc 128b 38.8 MiB/s 145.9 MiB/s twofish-cbc 128b 80.5 MiB/s 116.7 MiB/s aes-cbc 256b 347.5 MiB/s 750.6 MiB/s serpent-cbc 256b 50.4 MiB/s 142.8 MiB/s twofish-cbc 256b 101.1 MiB/s 116.6 MiB/s aes-xts 256b 802.2 MiB/s 804.7 MiB/s serpent-xts 256b 139.5 MiB/s 137.8 MiB/s twofish-xts 256b 110.7 MiB/s 109.7 MiB/s aes-xts 512b 674.9 MiB/s 666.1 MiB/s serpent-xts 512b 139.3 MiB/s 139.0 MiB/s twofish-xts 512b 109.1 MiB/s 109.3 MiB/s root@ubilinux4:~# uname -a; cat /etc/*release /etc/*version Linux ubilinux4 4.9.18-ubilinux+ #5 SMP Wed May 3 12:26:05 IST 2017 x86_64 GNU/Linux DISTRIB_ID=ubilinux DISTRIB_DESCRIPTION="ubilinux 4-beta1 (dolcetto)" DISTRIB_RELEASE=4.0 DISTRIB_CODENAME=dolcetto PRETTY_NAME="ubilinux 4-beta1" NAME="ubilinux" VERSION_ID="4-beta1" VERSION="4-beta1 (dolcetto)" ID=ubilinux ID_LIKE=debian ANSI_COLOR=1;34 HOME_URL="https://ubilinux.org/" SUPPORT_URL="mailto:ubilinux@emutex.com" BUG_REPORT_URL="mailto:ubilinux@emutex.com" 9.0 -
Thanks, there are a few versions of the up^2 which one was that (N3350, N4200, x5-E3940)?
cat /proc/cpuinfo | grep model | tail -n 1
I performed the test on a N4200 with 8GB DDR4.
