install, i8042 and other errors
Phil Miesle
New Member Posts: 2
Trying to install. Finding similar but not entirely the same error stack as https://up-community.org/forum/public-ubilinux/1235-unable-to-install-ubilinux#3686
Recap: USB created with Rufus, MBR with UEFI, dd mode. Boot, F7 and select USB (stick), Install (serial console)
get the following errors and then stuck:
And...that's all the further it gets after less than 2 seconds...
efi: requested map not found. esrt: ESRT header is not in the memory map. dw_dmac INTL9C60:00: Missing DT data dw_dmac INTL9C60:01: Missing DT data Failed to find cpu0 device node i8042: Can't read CTL wile initializing i8042
I am experiencing a similar issue sometimes when booting.
This is quite a big problem as the device will be stuck like this until i recycle the powerefi: requested map not found. esrt: ESRT header is not in the memory map. dw_dmac INTL9C60:00 Missing DT data dw_dmac INTL9C60:01 Missing DT data Failed to find cpu0 device node i8042: Can't read CTR while initializing i8042 Loading, please wait... /dev/mmcblk0pc: clean, 206658/1908736 files, 2479805/7621888 blocks _
Any help with this would be helpful
Thanks -
Dear daveyjones
this forum post is 5 month old and those error are perfectly harmless (are related to devices present in the bios information but not on the board)
The device that remain stuck otherwise is not.
1) Please check that your system is updated with the latest Ubilinux version (4.0) and bios version (depend on the board that you have) and see if there still problems
2) if there are still some issue please describe better the behaviour of the board
2) please provide a full log (sudo dmesg > log.txt) of the system
Regards
Nicola Lunghi
- 105 Announcements & News
- 185 Welcome Developers!
- 49 Tech Updates
- 693 UP Products
- 11 UP 7000
- 10 UP Xtreme i12
- 11 UP Squared Pro 7000
- 19 UP Squared V2
- 59 UP 4000
- 35 UP Squared 6000
- 60 UP Squared Pro
- 143 UP Xtreme
- 837 UP Squared
- 222 UP Core
