Power on
Quick question about powering the upboard, sorry if this has been asked before.
Does the upboard start up once it has power (similar to a Pi), or do I need to switch it on manually. I want to hide the device behind a TV at a property that doesn't always have power.
Thanks.
    If you un-plug and re-plug the power cable, the board should start up automatically.
    If you power off the board, you need either to press the power button or un-plug and re-plug the power cable.
